I have a colleague who is having trouble with Python initializing for the ScriptEditor. We’ve worked through ensuring PIP functions and can reach pypi.org. I can post the log file if needed, but here is the crux of the issue:
Info 12/2/2025 7:54:06 PM [RhinoCode] Running process: C:\Users\<user>\.rhinocode\py39-rh8\python.exe -I -m pip --isolated --disable-pip-version-check list --path "C:\Users\<user>\.rhinocode\py39-rh8\site-envs\default-ohYuJBYv" --format freeze
Error 12/2/2025 7:54:06 PM [RhinoCode] Error loading component settings | System.TypeInitializationException: The type initializer for 'Rhino.Runtime.Code.Storage.StorageData' threw an exception. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: This implementation is not part of the Windows Platform FIPS validated cryptographic algorithms.
at System.Security.Cryptography.MD5CryptoServiceProvider..ctor()
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args)
at System.Security.Cryptography.MD5.Create()
at Rhino.Runtime.Code.Storage.StorageData..cctor()
at Rhino.Runtime.Code.Storage.Local.FileStorage..ctor(Uri uri)
at RhinoCodeEditor.Editor.RCE.EnsureConfigs()
