I hope I’m in the right forum. I looked on here and could not find an answer to my problem. I’m attempting to write a batch file / ini file that will allow for an unattended install for Rhino 5 (Windows) where the installer will default to Network Install (connect to the Zoo).
I have used the WORKGROUP_NODE in various ways - in the setup.ini and in the command line: msiexec.exe /i"D:\Installers\setup_x64_en-us.msi" INSTALLDIR=“C:\Program Files\Rhinoceros 5 (64-bit)” WORKGROUP_NODE=1 INSTALL_EN=1
What am I doing wrong? Every time I run the batch, variables such as COMPANYNAME work and Install_EN=1 work, but not WORKGROUP_NODE. The radio button for STANDALONE is always selected by default and will not change to NETWORK.
Do you know which service of Rhino you are trying to install? If you have a Rhino CD, the SR number is printed on the CD.
The reason I ask is that there have been numerous installer fixes of the life of Rhino. Thus, you might just download the latest version of Rhino and try it.
I am also having difficulty scripting a batch install of the latest release of Rhino 5
Version 5 SR9 64-bit
(5.9.40617.14345, 6/17/2014)
Similar to jdeen … the “rhino5setup_en-us_x64.msi” is not able to accept WORKGROUP_NODE=1 paramater. I have the setup.ini file within the same located/folder as the MSI.
Setting it to WORKGROUP_NODE=0 and even enabling RMA_LICENSENODETYPE=Evaluation works perfectly. However, the MSI refuses to recognize the parameter to set installation to utilize Zoo license manager.
