Scriptable NamedSelections Issue
I’m running into an issue with the scriptable version of NamedSelections when trying to create a new selection for objects on reference layers.
Use worksession to attach a model to the current model
Run NamedSelections interactively
Select an object on a reference layer from the attached model
Create a new NamedSelection
All works as expected. Now, select an object on a reference layer and run the scriptable command
-NamedSelections Save
It reports no objects selected.
What I am trying to do is write a command script (not RhinoScript, etc.) where I can take an object on a reference layer (that I have access to in the script early on) and be able to select it later in the script. I can’t set its object name since it is on a reference layer but would like to be able to add it to a named selection set for later selection in the script.
Thanks, Larry
Hi @LarryL
I see this bug as well. Thanks for the report. We’ll get it fixed so that your script will work.
https://mcneel.myjetbrains.com/youtrack/issue/RH-65064
Thanks Travis!
@LarryL you’re welcome! I was able to get this patched up today and provided that it passes testing you should see it ship out with 7.9.
