G’day Everyone,
Does anyone have a script for saving a file with date and/or time appended to the front? Similar to incremental save functionality it will create a new file each time and/or each day it is run.
regards,
Nick.
G’day Everyone,
regards,
Nick.
You can try the python script below, roughly tested on Windows only.
SaveFileWithDateTime.py (2.3 KB)
Some rules to note:
The date_time and filename format looks like below, both underscore seperators are required:
20160220_0200_YourFileName.3dm
which equals:
YearMonthDay_HourMinute_YourFileName.3dm
Using this format, files should appear ordered in your explorer window. Note that if a file is saved in the same minute, a backup file is created if the option is enabled under:
Rhino Options / Files / Save / Create backup (*.3DMBAK) files when saving
c.
Good work, thanks @clement.
Hi clement,
If I want to re-export to file name with likes: object01,object02,object03,… by once use the python.
Regards,
Alen
