Layer numbers could start with 1 or a selected numbers and then just add 1 to each additional layer. Example 1, 2, 3 all the way up to 1000 each would have a random color. I have been using a template file with around 600 layers I set up by hand but now my project will have over 1000 different layers.
I have a simple numbered layer generator:
AddNumberedLayers.py (1.3 KB)
It does not do random colors though. That could be added, however I have found that truly random colors are often too dark for my liking. So I have a whole bunch of scripts to generate various kinds of random colors to selected layers. Below are a few. If you see one that generates colors you like, let me know and i can incorporate it into the numbered layer generator.
RandomSaturatedColorSelLayersNew2.py (938 Bytes)
RandomLightColorSelLayersNew2.py (1.0 KB)
RandomColorAllLayers.py (409 Bytes)
Mitch
Thank you again…No need to combine them, it’s no problem to just run 2 scripts. This will save me a ton of time.
Brian
I have not upgraded to R8 and I have no clue how to run a grasshopper script, that said I thank you and McNeel anyway. Most companies would just ignore a post like this.
Brian
