MAD3D
March 25, 2017, 9:20pm
1
Hi
I have this simple script to extract my wireframe, it works fine, but I want to Show surface isocurve be set to “on” in the end of the script.
How can I add this?
! _Select _Pause _-Properties _Object _ShowIsocurves _No _EnterEnd _ExtractWireframe
Hi @MAD3D ,
below should yield the same result as above macro without changing the isocurve density:
def ExtractEdgeCurves():
msg = "Select surfaces and polysurfaces to extract edge curves"
ids = rs.GetObjects(msg, 8 + 16, True, True, False)
if not ids: return
results = []
rs.EnableRedraw(False)
for id in ids:
rc = rs.DuplicateEdgeCurves(id, False)
if rc: results.extend(rc)
if len(results) > 0:
rs.SelectObjects(results)
rs.EnableRedraw(True)
ExtractEdgeCurves()
c.
MAD3D
March 26, 2017, 3:34pm
3
Thanks a lot @clement , it´s Perfect!!!
clement:
if not ids: return
results = []
for id in ids:
ExtractEdgeCurves()
