Sub CountAllInstancesOfAllBlocks
arrNames = Rhino.BlockNames(True)
If IsArray(arrNames) Then
For Each strName In arrNames
Rhino.Print strName & " = " & CStr(Rhino.BlockInstanceCount(strName))
Next
End If
End Sub
I add a _ in front of all command to indiquate that it’s an english command :
Hi @francois1, the underscore in front of a command only works for Rhino commands not for script code. Eg. you can make your french Rhino accept the english command name _Join or “_Explode”.
next step, I would like to export blocks like this script :
' ExportBlockCount.rvb -- May 2010
' If this code works, it was written by Dale Fugier.
' If not, I don't know who wrote it.
' Works with Rhino 4.0.
Option Explicit
Sub ExportBlockCount()
Dim arrBlocks, strBlock, strName
Dim objCounts, objKey
Dim objExcel, objBook, objSheet, nCell
' Get all of the block instances in the document
arrBlocks = Rhino.ObjectsByType(4096)
If IsNull(arrBlocks) Then
Call Rhino.Print("No blocks to export.")
Exit Sub
End If
' Create a dictionary object for counting blocks
Set objCounts = CreateObject("Scripting.Dictionary")
' Count the blocks
For Each strBlock In arrBlocks
strName = Rhino.BlockInstanceName(strBlock)
If objCounts.Exists(strName) Then
objCounts(strName) = objCounts(strName) + 1
Else
Call objCounts.Add(strName, 1)
End If
Next
' Create a Excel object
Set objExcel = CreateObject("Excel.Application")
objExcel.Visible = True
' Initialize Excel
Set objBook = objExcel.Workbooks.Add
Set objSheet = objBook.Worksheets(1)
' Place titles on sheet
nCell = 1
objExcel.Cells(nCell, 1).Value = "Block Name"
objExcel.Cells(nCell, 2).Value = "Count"
nCell = nCell + 1
' Write the blocks and counts to the sheet
Call Rhino.Print("Block counts:")
For Each objKey In objCounts
objExcel.Cells(nCell, 1).Value = CStr(objKey)
objExcel.Cells(nCell, 2).Value = CStr(objCounts(objKey))
' Print to command line too
Call Rhino.Print(" " & CStr(objKey) & " = " & CStr(objCounts(objKey)))
nCell = nCell + 1
Next
End Sub
' Drag & drop and alias creation stuff
Rhino.AddStartUpScript Rhino.LastLoadedScriptFile
Rhino.AddAlias "ExportBlockCount", "_-RunScript (ExportBlockCount)"
