I would like to add a text dot to each polysurface/extrusion on the screen with a different number.
Brian
Brian
The attached will add a sequentially numbered text dot to each surface, polysurface or extrusion selected. Option to start at whatever number you want (default is 1).
–Mitch
SequentialNumberBreps.py (461 Bytes)
Thank you kindly Sir…I will give it a try today.
Brian
