I have a script (Thomas Ags’ GearGen script) that runs every time I open a V5 file. Is there anything I can do to stop this?
There’s nothing listed in the ‘Run these commands every time Rhino starts’ box. Btw, I want to keep the script installed as it’s great!
Is it by any chance listed in Options>Rhinoscript?
–Mitch
Yes. There are several others listed too, but none of those run on start up.
OK, if you remove it from the list, does it still run at startup?
–Mitch
Hi Matt- if you edit the script and remove or comment (put a ’ in front) the line marked below
Option Explicit
GearGen <<<<<< This line
Sub GearGen ()
Etc etc
the script will not run at startup, but it will also not run with LoadScript, you’ll need to use Runscript.
