Script: Match Model Layer Visibility to Detail Layer Visibility
Have you been wanting to duplicate your Model layer visibility in a Detail?
Background: Prior to Rhino 8, global layer on off was the only option. Rhino 8 added Model visibility, however Rhino 8 does not provided a way to “match” the model visibility to an existing Detail layer visibility.
Solution: This Python script will do this for you. match_detail_to_model.py (1.3 KB)
  1. You will need to the command RunPythonScript every time you want to run it.
  2. First make the details active, and run the attached python script.
  3. Make sure and test. It seems to work for me, so far.
Let us know if is works for you.
Sincerely,
Mary Ann Fugier
