Script is 4X! bigger than it needs to be, please help
Hi, studying RhinoScript 101 by David Rutten, pg 58 ‘Geodesic Curve’
After studying the script closely I deleted about 100 lines of apparently unnecessary codes, and discovered the script still works perfectly!. How? Why would David write almost 100 lines more code than necessary? I deleted everything after line 32 and the script works just fine.
L31 Call Rhino.Print("Geodesic curve added with length: " & dblNewLength)
L32 End Sub
Could someone please explain. Copy of script below.
Justin
Option Explicit
Call GeodesicCurve()
Sub GeodesicCurve()
Dim strSurfaceID
strSurfaceID = Rhino.GetObject(“Select surface for geodesic curve solution”, 8, True, True)
If IsNull(strSurfaceID) Then Exit Sub
Dim arrV
arrV = GetR2PathOnSurface(strSurfaceID, 10, "Start of geodesic curve", "End of geodesic curve")
If IsNull(arrV) Then Exit Sub
Dim dblTolerance : dblTolerance = Rhino.UnitAbsoluteTolerance() / 10
Dim dblLength : dblLength = 1e300
Dim dblNewLength : dblNewLength = 0.0
Do
	Call Rhino.Prompt("Solving geodesic fit for " & UBound(arrV) & " samples")
	Call GeodesicFit(arrV, strSurfaceID, dblTolerance)
	dblNewLength = PolylineLength(arrV)
	If (Abs(dblNewLength - dblLength) < dblTolerance) Then Exit Do
	If (UBound(arrV) > 1000) Then Exit Do
	arrV = SubDividePolyline(arrV)
	dblLength = dblNewLength
Loop
Call Rhino.AddPolyline(arrV)
End Sub
Sub GeodesicFit(ByRef arrVertices, strSurfaceID, dblTolerance)
Dim dblLength
dblLength = PolylineLength(arrVertices)
Dim dblNewLength
Do
	Call SmoothPolyline(arrVertices)
	Call ProjectPolyline(arrVertices, strSurfaceID)
	dblNewLength = PolylineLength(arrVertices)
Loop
End Sub
Sub SmoothPolyline(ByRef arrVertices)
Dim arrCopy : arrCopy = arrVertices
Dim i, j
For i = 1 To UBound(arrVertices) - 1
	For j = 0 To 2
		arrVertices(i)(j) = (arrCopy(i - 1)(j) + _
			arrCopy(i)(j) + _
			arrCopy(i + 1)(j)) / 3.0
	Next
Next
End Sub
Sub ProjectPolyline(ByRef arrVertices, strSurfaceID)
Dim arrProjPt, i
	arrProjPt = Rhino.BRepClosestPoint(strSurfaceID, arrVertices(i))
	If Not IsNull(arrProjPt) Then
		arrVertices(i) = arrProjPt(0)
	End If
Next
End Sub
Function GetR2PathOnSurface(strSurfaceID, intSegments, strPrompt1, strPrompt2)
GetR2PathOnSurface = Null
Dim ptStart, ptEnd
ptStart = Rhino.GetPointOnSurface(strSurfaceID, strPrompt1)
If IsNull(ptStart) Then Exit Function
ptEnd = Rhino.GetPointOnSurface(strSurfaceID, strPrompt2)
If IsNull(ptEnd) Then Exit Function
If (Rhino.Distance(ptStart, ptEnd) = 0.0) Then Exit Function
Dim uvA : uvA = Rhino.SurfaceClosestPoint(strSurfaceID, ptStart)
Dim uvB : uvB = Rhino.SurfaceClosestPoint(strSurfaceID, ptEnd)
Dim arrV() : ReDim arrV(intSegments)
Dim i, t, u, v
For i = 0 To intSegments
	t = i / intSegments
	u = uvA(0) + t * (uvB(0) - uvA(0))
	v = uvA(1) + t * (uvB(1) - uvA(1))
	arrV(i) = Rhino.EvaluateSurface(strSurfaceID, Array(u, v))
Next
GetR2PathOnSurface = arrV
End Function
Function SubDividePolyline(ByRef arrV)
Dim arrSubD()
ReDim arrSubD(2 * UBound(arrV))
Dim i
For i = 0 To UBound(arrV) - 1
	'copy the original vertex location
	arrSubD(i * 2) = arrV(i)
	'compute the average of the current vertex and the next one
	arrSubD(i * 2 + 1) = Array((arrV(i)(0) + arrV(i + 1)(0)) / 2.0, _
		(arrV(i)(1) + arrV(i + 1)(1)) / 2.0, _
		(arrV(i)(2) + arrV(i + 1)(2)) / 2.0)
Next
'copy the last vertex (this is skipped by the loop)
arrSubD(UBound(arrSubD)) = arrV(UBound(arrV))
SubDividePolyline = arrSubD
End Function
Function PolylineLength(ByRef arrVertices)
PolylineLength = 0.0
Dim i
For i = 0 To UBound(arrVertices) - 1
	PolylineLength = PolylineLength + Rhino.Distance(arrVertices(i), arrVertices(i + 1))
Next
End Function
If you close Rhino and restart, does your shortened script still run?
The shortened script does not work when I shutdown and restart Rhinocerous. but when I retest the original script then retest the shortened script the shortened script does work.
When you load a script, it resides in the system’s memory until you close Rhino. Thus, you might have shortened the script. But the missing piece was still in memory, thus the script continued to work.
Read through the introduction section of the RhinoScript help file. It’s pretty sort, but contains some good information.
http://4.rhino3d.com/5/rhinoscript/index.html
Yeah, I would consider that a bug, not a ‘feature’. It should just run the script I tell it to.
It is indeed a useful feature and not a bug. For instance you could tell rhino to automatically load some files with functions you defined which are useful in your everyday scripting work. So to speak some sort of library. This is actually quite convenient and can save time usually needed to paste together code snippets from previous scripts. In ironpython there are much more sophisticated ways to deal with existing code, external libraries and so on. So you might what to consider to take a look into the python world. It is in the end a much more powerful scripting tool for rhino. I just shifted from vbs/vb.net to python.
Thanks for the input.
