I often have to go in to the Object properties of an object and set the Display Color, Linetype, Print Color, and Print Width to By Layer. It would be a significant time saver if there was a script that could do this for us. Any chance?
Thank you.
Thank you.
Try Match Properties (not scripting)
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/matchproperties.htm?
-_runscript (
arrObjects = Rhino.GetObjects("Select objects to reset properties source",,,vbtrue)
If IsArray(arrObjects) Then
For Each strObject In arrObjects
Rhino.print Rhino.ObjectColorSource(arrObjects, 0)
Rhino.print Rhino.ObjectLinetypeSource(arrObjects, 0)
Rhino.print Rhino.ObjectMaterialSource(arrObjects, 0)
Rhino.print Rhino.ObjectPrintColorSource(arrObjects, 0)
Rhino.print Rhino.ObjectPrintWidthSource(arrObjects, 0)
Next
end if
This seems to work too, with fewer loops:
-_runscript (
end if
Here is a python version:
ResetSpecificObjAttributesToDefault.py (1.1 KB)
I also added changing the object material source back to by layer, you can set an optional argument to not do that, just change the last
ResetSpecificObjAttributesToDefault()
to
ResetSpecificObjAttributesToDefault(mt=False)
–Mitch
is the way to do it, (another distraction)
The python is more sophisticated
You guys are awesome Thank you! Thank you! Thank you!
