Script for sorting blocks
Recently cleaned up a document which took ages because of alot of blocks that where assigned to layers that I wanted to get rid of. Usually when working the layer structure changes slightly so it is hard to commit to a 100 % method of sorting blocks on layers. Usually I have some nested objects which are set to layer, these are then placed in a block with additional objects - all of these is objects/blocks are then set to ByParent.
It would be usefull with a script that sets objects inside a block (first level deep) to ByParent but leaves the content in the nested block be. It is possible to do that with a slight modification of Pascals Script
MoveBlockObjectstoLayer.py (1.3 KB)
Hi @nilceros,
Here is a sample I wrote a while back. Perhaps it helps or is at least a good starting point.
test_byparent.py (2.0 KB)
– Dale
Really Nice would it be possible to set the layer from a list also?
