Script for extruding a face and preserve the position of adjacent faces?
As I got the call from the gallerist for my sofa, due to I build the wooden frame from 19mm wooden coreboard he cannot guarantee the exact same thickness as it will be produced not in Germany but in NYC. when constructing the whole sofa it might be of great help if there where a script to manage that so simply click the face and type in the mm extra or less similar to surface offset but with trimming included.
Thank you for your help! Hannes
http://recordit.co/F39ClFsL4I
Hi Hannes,
19mm and 3/4" are only 0.05 mm different. US sheet material with a nominal 3/4" size should have an actual size no smaller than 18mm (varies depending on the type of material). In this case I would think you can leave it to the maker to cope. Wood isn’t steel and manufacturing tolerances aren’t so tight.
Regards
Jeremy
Thank you @jeremy5 for clarifying. But such a script would be very handy for a lot of applications and use cases.
