Hi @eirannejad,
Working on getting you a sample of code but since 8.18 the script editor often gets stuck in ReadOnly mode if the code throws an exception via something like this:
def CreateButtons(self):
try:
# Add some code that will throw exception here
print(f"buttons_length: {len(self.buttons}")
except Exception as ex:
Rhino.RhinoApp.WriteLine(f"CreateButtons Exception: {ex}")
CreateButtons Exception: '<__main__.Form__Toolbar object at 0x0000025C88043700>' object has no attribute 'buttons'
Do you see this on your end? For me it happens anytime I throw an exception and close out of an Eto.Form that would have contained the âexception causing codeâ
I can only get out of the ReadOnly mode with a restart of Rhino, and even then, I sometimes still see a âRhinoâ process in my taskbar in Background Processes (Still trying to figure out if that is related to this or if that is caused by my code elsewhere)
I can still work in Rhino, create geometry, etc⌠but cannot use the ScriptEditor
What I see in the script editor when this happens:
What I see in my task manager AFTER completely closing Rhino:
Thanks for your help!
System Info
Rhino 8 SR20 2025-4-25 (Rhino 8, 8.20.25115.10001, Git hash:master @ 20b43256bd826988cbf7973fffd80164d23de83a)
License type: Commercial, build 2025-04-25
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.14
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 12-18-2024 (M-D-Y).
> External USB display device with 4 adapter port(s)
- Windows Main Display attached to adapter port 0
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-26-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Redraw scene when viewports are exposed: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp âDatasmith Exporterâ 5.1.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll âEnscape.Rhino8.Pluginâ 4.2.1.88
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp âCrashâ 1.4.0.0
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp âD5 Live Sync for Rhinoâ
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp âRhinoCodePluginâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.20.25115.10001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
