Script Editor run shortcut
@eirannejad did you ever consider adding F5 or something else as shortcut to run the current script?
Uhm F5 should be the default shortcut for “Run” in script editor in Rhino 8 and WIP. Doesn’t it work for you?
Rhino WIP has customizable keyboard bindings now:
Thanks for the reply. I think F5 used to work in the past but for some reason it is not set in my Rhino 9 WIP options currently?
I tried ‘Restore Defaults’ but nothing changed so I set it manually.
Now F5 works in Rhino but not in Grasshopper
Okay I might have messed it up. Will push a fix.
Update:
Yup. definitely me messing it up. Will fix.
Oh an also we did not release a WIP this week so you have the much older build.
Thanks :slight_smile:
That’s alright. The F5 thing also isn’t a critical thing right now. I thought it worked in the past and I used it and all of a sudden it doesn’t do anything?
All good…
