Script Editor - Delete and save grayed out in project
I am unable to delete and edit scripts in pa project in Script Editor. Saving the project is also grayed out.
I also get this error whenever I try to open one of these components
Can not open, edit or delete any items added to a project after a certain point. I have to rebuild a new project. This happen to all items. I have full read and write permissions on these file locations…I even moved the project to my desktop. Running rhino in safe mode.
To remove items from the project I have to open the project.rhproj file in a text editor and manually remove the remove any entries related to the item I am trying to delete, LOL.
What is going on with this thing. Should i just factory reset Rhino?
@benjamin.moulton Sorry for the troubles. This is definitely a bug. There was a related fix I pushed to 8.19 last week so I would really appreciate if you can check the latest 8.19 SRC as well. I am traveling at the moment but will look into this end of the week and will make sure it is fixed.
I am able to delete items now, however the button to edit/create an icon is permanently grayed out. There doesn’t seem to be a way to add icons to component.
I’m on latest SR and also struggling with inability to remove items in the script editor. Button is greyed out.
I managed to now enable the functionality by adding an existing command again, which temporarily turned on the ability to delete items.
Looking into this and will update. Sorry for the late reply.
Update:
I can replicate this and pushing a fix into 8.24 SRC
Hi, using Rhino 8, any update in this thread?
