Script based on a changing polyline (list with variable item count)
I’m using a fairly repetitive script to build a structure along a line. As I want each segment of the polyline to display differently, I end up doing a lot of copy paste. My script worked fine, until I realized it doesn’t work at all when I change the segment count.
when I remove the last segment this happens… :cry:
I guess it has to do with all the ‘‘list item’’ i used… How could I re-write this script more efficiently without losing the ability to parameter each section independently AND use polylines of varying segment count?
Structure4.gh (240.7 KB)
Structure.3dm (53.8 KB)
Thank you very much,
Florence
i have tried some thing
u can have a look into it
Structure4_r00.gh (48.7 KB)
way better! However I still have the same problem, when changing for a 2 segment polyline for instance, it doesn’t work. How should I work with the number of data in the panels when changing the source polyline?
Thanks so much!
u try to graft the polylines
so it should work
