Scripcontext Module Error in latest Rhino Update [Everything is Broken]
As of the latest Rhino update, import scriptcontext in GHPython is now broken for me:
EditPythonScript initialization
Failed loading the scriptcontext module.
Please restore installation paths and try again.
  Error: Runtime error (Exception): Error
Traceback:
  line 18, in <module>, "/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp/RssLib/scriptcontext.py"
  line 1, in script
As a result, every component we use in the firm is now broken and all work has come to a halt.
What does “Please restore installation paths and try again.” even mean? How does one do that?
not amused.
@ed.p.may
System:
  • MacBook Pro M1 (2021)
  • MacOS v26.6.2 (Tahoe)
  • Rhino v8.36.26279.07002, 2026-10-06
The (not so) hotfix will be in todays 8.36 release, if you need it now i can send it along.
Thanks @Japhy - I’ll keep an eye out for that update later today then. Appreciate it.
-e
I seem to have the same problem with 8.SR36(.26279.7001,2020-10-06)
Confirmed patch works as expected. No error now on v8.36.26282.15002, 2026-10-09
thanks @Japhy
@ed.p.may
