Screw library
Hi AUSSIE,
Thank you for your hints. Unfortunately I’m a bit busy right now so I’ll try this later. Anyhow, these were the two files I tried:
3176T310_VIBRATION-DAMPING U-BOLT.STEP (1.5 MB)
4429K368_LOW-PRESSURE BRASS THREADED PIPE FITTING.STEP (1.8 MB)
// Rolf
Hi Chris,
they have step iges formats, you can change the download format 2D 3D step etc see image below.
Hi Rolf,
I think I figured out your drama, it’s pretty impossible to soften an item with actual threads drawn because the crest and the root of the thread drastically limit the softening value to very small values, say 0.001mm, I would not even bother at this value. The pipe fitting is pretty easy on the eye now, perhaps put some fillets into the U-Bolt assembly. HG
EXCELLENT! I am now cooking with gas. Cheers mate!
