I found a problem when using the api.scene.getScreenshot() function to save a screenshot of the viewer.
In Firefox (v.73.0.1 for OSX) the image gets the bottom left quarter of the viewer and stretches it to the actual resolution: for example if the viewer is 640x480 pixels in size, the output image takes the bottom left 320x240px part and scales it by 200%.
The same behavior occurs regardless of the models, for example also on the first API example, using the console (I put the demo here: https://www.marcotraverso.it/temp/sd-demo-01.php)
Both Chrome and Safari work correctly. I’m using the most recent API version (2.19.3).
Am I missing something? Is there a solution or a workaround for making it work?
Thanks in advance
Marco
