Hi I need to draw a point on the Cplane under the mouse… but the routine I grabbed from the samples has a big offset?
class CustomConduit : DisplayConduit
protected override void PostDrawObjects(DrawEventArgs e)
RhinoView view = RhinoDoc.ActiveDoc.Views.ActiveView;
var P = Cursor.Position;
Transform xform = view.ActiveViewport.GetTransform(CoordinateSystem.Screen, CoordinateSystem.Camera);
Point3d world_point = new Point3d(P.X, P.Y, 0.0);
world_point.Transform(xform);
e.Display.DrawPoint(world_point, Color.DarkRed);
and this is what I am getting? How can I get a point directly under my mouse
I am not using any kind of GET, I need this outside of any of those routines.
dale
(Dale Fugier)
2
Hi @ChristopherBotha,
This:
should be this:
Transform xform = view.ActiveViewport.GetTransform( CoordinateSystem.Screen, CoordinateSystem.World // << );
– Dale
Hi Dale.
Exact same offset. Except only in one window.
stevebaer
(Steve Baer)
4
Change
to
RhinoViewport viewport = e.Viewport;
The proper viewport is passed to the conduit for each viewport being drawn.
You also need to make the change that Dale suggested.
Thanks. Will give that a whirl!
nope, same offset using this code.
stevebaer
(Steve Baer)
7
Ah, Cursor.Position is in screen coordinates, not to local client coordinates of your window.
Call
P = view.ParentView.ScreenToClient§;
to convert the screen point
That fixed it up, thank you!
Ha! Was going for an implementation of Zbrush LazyMouse for freehand sketching… remember to turn off overrides before exiting a command
(lazyMouse working great though, thanks for the help.
