Is there anyone aware of a screen printing shop who utilizes Rhino? I have created dozens of ready to go T-shirt designs, yet in order for all the screen printers I’ve communicated with to accept my designs they want a full color Adobe Illustrator file, despite a Rhino file having all the info they could use.
I have tried to export various file formats, Including AI, I can either export the vectors and not the colored surfaces, or if I save as any color format, it becomes a bitmap. If only a print shop owned a copy of Rhino!
For 2D graphics work, it’s best to use 2D graphics software. You can fillet a fish with a bread knife but it will be tedious to say the least.
Hi @Greg_Lopez
I agree with @Lagom’s point on using the right tool for the job, but if Rhino is what you have available, hatches export well to Illustrator. I assume that what you have is surfaces, and the do not export - hatches do, and even include colour.
I reckon the reason why printers (in all forms) generally accept primarily Adobe files is consistency. There’s simply a smaller risk of errors if using only Adobe files. This - at least to an extend - prevents you (the customer) from coming back and saying: “That’s not the right blue!”, “Those lines are too thick!” and “How did that page number end up at the top instead of the bottom?”. If it’s in the AI/PDF file, it prints; If it’s not in the AI/PDF file, it doesn’t.
And with that in mind, I’d recommend you to check any exported Illustrator file coming out of Rhino in Illustrator itself before committing to printing.
HTH, Jakob
PS You could ask the printer if a PDF from Rhino could suffice.
For screen printing, all you need is files to cut the masks. The colours, Pantone, RAL, NCS, etc. you can specify otherwise. To cut the masks, all you need is vector PDFs containing the outlines to be cut, which you can save from Rhino.
Thats the beauty of working with the limited tools available at hand.
Also who has time or energy to use things like gimp or Photoshop ?
Eew.. software..
For screen printing, you don’t want to use Photoshop. You should use Illustrator.
Yeah, mask cutting needs curves aka vectors
Potato potatas same story
still waiting for someone to create a grasshopper code that can do taxes or invoices
Keep everything in Rhino![]()
How bizarre.
Real life is more stranger than fiction after all ![]()
