Scope box function like in Revit
I’d like to ask if it’s possible to achieve a scope box functionality similar to Revit using VA. This would greatly facilitate facade detail design. Based on my current understanding, VA’s section feature only controls the width and depth of the display area, but not the height? So the range of the generated 2D drawing cannot be controlled?
best,
Hi @microinspire, I take note of this requests for future versions.
Right now, you can control the vertical limits of a section view by hiding Levels (from the Level Manager), or if you are in the page layout, with the Detail frame control points.
ok, thanks for your reply. Scope box will be very very helpful for real project. Then I need to use a workaround now…….
