Scaling the lines of a TreeView
Hi. I am using RhinoWindows.Forms.Dpi.ScaleSize to scale the size of controls in my plugin in order to support 4k monitors. However this does not work for TreeView controls. How can I scale the lines of the TreeView please?
Thanks
Paul
Hi @pkinnane,
Are you using WinForms, WPF, or Eto?
– Dale
Hi @dale - it’s the System.Windows.Forms.TreeView on a System.Windows.Forms.UserControl, so WinForms.
Paul
Hi @pkinnane,
WinForms should size your tree view appropriately - there should be no reason to scale (e.g. resize) the control yourself.
A few notes that might be worth reading:
– Dale
Thanks Dale. I had the TreeView.ItemHeight set to 19 which was the cause of the problem.
Paul
