Hi everybody!
I created solids, but I think it’s difficult way to find plane with middle point of curves on the target surface
Can you suggest an easier way for scaling?
I tried to search for something on www.food4rhino.com but unsuccessfully.
I will be glad of any help.
the main issue is, let’s say the breps were created in a different way, then it might happen that they will be scaled along the wrong axis, and that will happen in both cases -which is not that much of a reliable method then…-
may I ask if those initial breps are referenced from Rhino, or obtained in GH as extrusions, loft or sweeps?
because if you are also building them in GH, then I believe we can find much more reliable ways to extend them
in simple words, if they are not referenced directly from Rhino, what happens before those:
