Hey everyone,
I’m studying an atrium in order to check which edge would give me the best benefit in terms of daylight. However, I havent been able to pick one of the edges and scale it in one direction ony, so I would like to ask for your help. Instead the script I built is locking one and scaling the other three.
Thank you in advance.
GEOMETRY.gh (14.5 KB)
Looks like you want to move one of edges of the inner surface/curve, not “scale” it?
Here is a simplified version of what you have now:
GEOMETRY_2018Jan29a.gh (12.3 KB)
Standby…
Great Joseph!
Thanks for cleaning the script. Exactly, I would like to move (or offset) each edge, but one at a time.
Thanks a lot.
How about this?
GEOMETRY_2018Jan29b.gh (14.3 KB)
P.S. I just noticed a minor, inconsequential error. The ‘Index’ slider is limited to integer values from one to four; should be zero to three. It works anyway (off by one) because the ‘W (Wrap)’ input is true for both Cull Index and List Item.
Joseph! Amazing, it did work perfeclty. I set the slider correctly.
Thanks a lot!
