I’m a trying to scale a rhino model. I wanted to laser cut it. I’m new to rhino and having a bit of challenges scaling my model down to 3D print. It is a12 meter box but I need it to be 0.3048m squared.
Any help would be awesome
Rhino Model.3dm (6.1 MB)
Hi Darnell - select youir objects, use Scale
, snap the base point to one corner of the box, the first reference point at the next corner, 12m away and then type in “.3048m” and Enter. Note some things may scale to a thickness to small to print…
Thanks for responding. I tried this and it seems the height does not scale. Any idea why?
Hi Darnell -
That sounds like you have used the Scale2D
command instead of the Scale
command.
Also, FWIW,
No, it’s a 1.2 meter box:
Oh. Thank you.
