This is in v5, made it kind of work with cage edit (2,2,2 - linear) - where is the ‘Scale Edge’ command gone?
Thanks!
H
Thanks!
H
Hi Hannes - sub-object select (ctrl-shift click) the edge, then use the regular transform commands for scale, move, rotate etc.
ctrl+shift click an edge to sub object select it, then use scale 1d to scale the edge.
@pascal @theoutside I’m regularly using it for multiple selection, never used it for one single object. Hurrayyy
