Hi, I’ve a circle with a radius line (DimRadius), then, when I apply the _Scale2d command the circle is transformed effectively but the radius line is not transformed.
How do I do that?
It works for me.
You can modify the radius with dedicated command “_modifyradius” also. I’ve tested and all is OK.
I sketched the circle r=10, after sketching I inserted the DimRadius (R10), run “_modifyradius” command, change r to r=25 and the DimRadius has been updated to R25
Scale2D works fine in Rhino 7.8 - when Scale2D changes the circle, the DimRadius adjusts automatically.
