Scale2D by Gumball bug
When I scale in 2D using the Gumball and entering the units, the geometry collapses to a single point.
In both V8 and the WIP.
2026-06-02_Gumball.3dm (844.4 KB)
According to the Help, it should just work with entering the model units.
And it does work using the square scale handles in 1D and 3D.
When it is not intended to work in 2D, then it should at least do nothing.
And not throw the geometry into a black hole.
Must be a bug.
I think 2D uniform scaling with a distance should be done with a scale handle and pressing shift.
If this issue is not considered important enough (?) to be addressed, it would be good to adjust the help.
Or throw a warning.
Or remove scale with units completely.
Or make it working as expected?
As it is now, it leads to immediate disappointment.
