Scale1D without changing the texture mapping of an object?
Say I have a door for instance, and I want to use the Scale1D command it to make it a little wider. Is it possible for me to do so without changing the scale of the textures on it? So far, my workflow is that I use Scale1D and then I have to go back and adjust the texture mapping afterwards. It would be very convenient if I could cut out that last step somehow.
Thank you in advance for your help! (:
Yes, you can use WCS mapping to base the texture size on model units or in this case Planar mapping would work as well.
