When using scale1D, the object is no longer scaled from the basepoint. It appears to scale from the area centroid of the surfaces being scaled.
Hi Reed - if you press Enter without explicitly setting a base point, the center of the input bounding box is used.
The base point was selected before pressing Enter. This is not the cause.
any chance you could show a screen recording of what you are seeing?
