With grid snap disabled, the second reference point is exactly where the cursor is, as I expect it. However, when I enable grid snap, then the second reference point snaps to in between grid points.
Hi @feklee
Your scale operation starting point is the mid point of the line - which in this case falls exactly between two grid points. When you turn grid snap back on, it relates to the position of the scale starting point, not the . I’m not saying it’s logical, but that’s why. If you make a 6mm (or any even number) line, it will snap to the grid.
You can work around it by using SmartTrack - After setting your second reference point (the end of the line), move the mouse away from the end and then back, thus setting a smart track point at the end. That will force the grid snap to use the SmartTrack point as the reference instead of the first reference point. Try it out - it’s less complicated than it sounds in writing
HTH, Jakob
