I can’t edit scale in layout view in my latest Rhinoceros 6.
Please help.
Please help.
this?
Hi ,
The Edit button on the right to set scale does not work.
I click Edit and then key in 1 , enter, key in 72 enter but the drawing does not change. It just remain the same.
Best regards,
Godfrey Yin
Freycraft Marine Industries Sdn Bhd
I had the same bug happening yesterday after updating rhino.
Well for me Rhino multiplies everything i type into “meters in model” by 1000 which is confusing
To be clear, the edit button in this instance would bring up the paper size dialog, not the viewport detail settings. The image i posted requires you to select the viewport first.
Hi Godfrey - a few things have been fixed in this area recently - for now, you can activate the detail and then run the Detail
command > Scale and that should work.
Hi Pascal,
Thanks, it works only with the Locked ticked. The edit button works too with the locked ticked.
Best regards,
Godfrey Yin
I install the latest update and the Scale to Paper Edit button works even with the Lock ticked. It therefore can not be lock.
Another new issue is that Offset Surface turn out to be a Solid.
Do you have Solid=Yes in the OffsetSrf options?
Hi Godfrey - what button is that ?
Do you mean a toolbar button?
Dear Pascal,
The edit button as shown here. I can still edit even with the Locked tick.
Best regards,
Godfrey Yin
Dear David,
Ok, that fix it. Thank you.
Best regards,
Godfrey Yin
Dear Pascal,
While working with this latest version of Rhino 6, my computer hang up and I have to reboot. I have been using the same computer for Rhino 5.
Best regards,
Godfrey Yin
Dear Pascal,
Please ignore this email. My Windows 10 is the problem.
Best regards,
Godfrey Yin
