Hi Everyone,
I am working with a set of volumes that will later on be copied with vectors. However, before doing such, I am struggling with scaling volumes like in the screenshot (and attached rhino file). I believe I should select a different point for each set of volumes, but I can’t figure out how to do it without losing the tree structure I constructed. Is there any way to do it without losing the tree structure? Thank you!
Is not easier if you generate the two types of square size from the ground? As a surface and then elevate them in z with a series. A series for each type of surface, and when these surfaces are high you do the extrude or a simply loft ( if you elevate the curves). I think that its a better way to make what you want
Hi @akilli
I need to scale it because it is the recreation of an existing model, and It works with scale rather than rotating. And what I need to be scaled are the boxes surrounding the core in an alternated pattern (like in this following screenshots).
Maybe I’m missing something, but I still can’t see why you wouldn’t use a bit of rotation along the way.
Is this anything like what you’re looking for?
