On plugin page citing 1 year old Laurent comment "… I distributed the sources (to Mc Neel and others) but didn’t see some new work. … "
Edit:
and the “virtual sheet” size and resolution shouldn’t be used at all. At least the resolution.
Also, exporting the same geometries with a different camera location results in different position and/or size on the svg file. Sometime even resulting in an empty .svg file!
It behave like a “print”, but it should not. It’s an “export”.
Hi Riccardo,
you are right my plugin doesn’t work on Rhino 6, I didn’t tried to compile it for Rhino 6. It must not be difficult but it seemed not necessary as Rhino 6 export SVG… Like you I continue to use Rhino 5. I gave all the sources to someone but neither saw a result. I have no problem to put them somewhere as it is not rocket science.
I don’t remember everything but units in SVG are quite a mess. There is a logic but not so simple or not always well implemented in others tools. And yes it is more an export than a print.
I’m trying to import SVG (made in other software) to Rhino. Unfortunately, the issue with scaling is still present. The scaling factor is 118.111 and I’m wondering from where (SVG units are in cm)?
Are there any improvements in RH regarding this problem?
Is there any way to overcome the problem?
Hi Brian. Looking at the notes in RH-44145 - does that mean that svg is able to support / preserve arcs as arcs? I’d always assumed it was like Illustrator and everything became Beziers.
Attempted to export SVG from Rhino 8 with scale 1:1 and faced the same problem as initially described by Nolwenn. My current workaround for this is to export PDF, import to Inkscape as pdf, and export to SVG from there, which results in correct units on the SVG.
That post was 3 years ago - a lot has changed since then - can you post a sample V8 file that shows this problem? In which program are you opening the exported .svg?
Hello! It is irrelevant of files, any vector file when exported as svg will show up in other programs scaled down (in my case inkscape for example). I exported a sign to be lasercut, the design was circular, overal diameter 83cm. Sent the laser cutter guys a pdf, dxf, and svg of the same file. They told me both pdf and dxf had a diameter of 83, svg however was somewhere around 63. I verified this by opening the svg in inkscape, indeed it was scaled down, despite me exporting in 1:1. Anyway, not really a problem for me sinse the workaround is easy.
