How would you scale one edge of surface? I have a rectangle but want to pinch the bottom two corners in to make more of a trapezoid shape. I cant just draw the shape because it is a surface with a wave pattern in it and i cant recreate the surface
CageEdit?
Or you could use flowalongsrf.
you can sub select the edge holding Ctrl+Shift and the scale it either with the gumball or by command line.
There is also the FoldFace command.
Regards
Rodolfo Santos
