Having upgraded to rhino 8 I files will no longer save to the server I work from.
This happened when I upgraded to 7 and then at some point started to work after an up date.
Does anybody know if this issue is being looked at.
Hi Gurney -
Does that mean that this still works from Rhino 7?
Is there any error message when this happens?
Please run the Rhino SystemInfo
command and copy-paste the result here.
Hi
Yes rhino 7 works fine.
There is a possibility that the sever is not allowing Rino 8 to make the temporary save folder and that I need to tell the server to give permission. Not really sure and cant quite remember the detail of how V7 resolved. It was a long time ago! I have asked our IT department if this could be the case.
attached are 2 text file with the system info for 7 and 8
Kind Regards,
Gurney peterson
Phone: 01895 237 183
Address: Bridge Works, Iver Lane, Uxbridge, UB8 2JG
rhino 7 system info.txt (5.31 KB)
rhino 8 stystem info.txt (5.27 KB)
to answer the second question
There is no error - Rhino just becomes unresponsive and I have to force quit it.
Kind Regards,
Gurney peterson
Hi Gurney -
Please check the state of the advanced Rhino.Options.FileSettings.WriteLocalTempFileWhenSaving
option in both Rhino 7 and Rhino 8 to make sure they are set the same.
Hi Wim,
It is working now. I am not sure why it wasn’t before!
Thank you for helping me.
