Is there a way to save certain settings between sessions? For example, take a look at these options:
One of our users is complaining that he has to set specific settings every time he starts Rhino. I suggested that we just use the hyphenated version of the command with the options set. This could be tied to an icon or alias. That’s the only solution I can think of, so I figured I’d ask the question here before doing that for him.
Hi Dan - I guess that goes command by command - I think Sweep2 probably could be made to save between sessions if need be. I can put that on the pile. Meantime, a dash version with the desired settings is a good workaround.
RH-62217 Sweep2: save dialog settings between sessions
