Does anyone know if there is a scriptable vray command to save the VfB in vray with the choice to save only RGB channel, all channels separately or all channels in one single file?
I used this before:
VRayForRhinoNETInterface.VRayInterface.SaveVFBRenderToPath(filename, saveRGB)
where saveRGB = 1 --> saves only the RGB channel
saveRGB = 0 --> saves all channels separately
It worked fine in vray 2 but in vray 3 the parameter has no effect and all the channels are always saved.
Is there an updated VrayForRhinoNETinterface.dll for vray 3 ?
I could use also the command
SaveRenderWindow
but I’ll have only the RGB channel or whatever is active at the moment
