Hello. Our senior designer has just moved from rhino 4 to 5.
When she changes something in a document, after saving the “date created” stay as before.
In rhino 4, date created updated with every new save. is there a way to make rhino 5 behave as rhino 4 in this area? This is of value because of the way we back up with total commander. Thank you Noam
It sounds like RH5 is doing it right and something strange must have been going on with RH4. Can you explain in a bit more detail what it is that Total Commander is having problems with?
What I understand is that total commander backs up every time the create date moves foward.
Natasha says this was the same with rhino 2 & 3.
Quite a history lesson for me. Thank you for the quick reply. Is there any place in rhino to play with this setting or in windows ( 7 ) to define how files are archived?
No, but there should be a way to get Total Commander to pay attention to “Date Modified” instead - or just the “Archive” flag that should be automatically set by the OS when a file is modified and unset by the backup program.
Thanks. I will write to them now. All the best. Noam
