Is there a way to save the channel settings, before you close a Flamingo nXt render, so you don’t have to go back and recreate those settings with each iteration?
Sorry for the delay in getting back to you on this one. There isn’t a way to save these slider positions between renders currently but I believe they should stick like the adjust image settings do. I filed this as a bug here…
http://mcneel.myjetbrains.com/youtrack/issue/FL-6016
An alternate workflow that might help is to save out the render as an nxtimage file and then use the nxt image editor in the Flamingo drop down menu>Utilities flyout to edit the lighting.
I asked for that functionality in 2011…
It is pretty unfortunate how little attention nXt has ever gotten.
