I’ve just installed: BETA (9.0.26293.12303, 10/20/2026)
I tried saving a new template file with some modifications to the small object mm template and it crashed Rhino. I did it twice with the same result. I was saving to the default template file folder.
Does immediately saving (i.e. without the modifications) the factory-default version of the small object mm template as a new template also crash Rhino?
Does this happen after a reboot as well?
Does it work when saving to a different folder?
When Rhino crashes, does the “Sad Rhino” crash reporter pop up?
Thank you for all of your quick feedback. For your general reference, this was the first R9 beta I tried. After further testing, I’ve found that this beta has more fundamental problems on my system. It crashes without any “Sad Rhino” screen when doing lots of things including simply starting Rhino and trying to save the .3dm file without drawing anything in the model. I fully uninstalled and reinstalled twice, rebooting after the uninstallation, and I get the same behavior. I successfully run R6, R7 & R8. We make an optical design software plug-in for Rhino, so I use it nearly every day. I now see that the R9 release version is available. I installed that, but don’t yet have a license key to run it. I’ll follow up if I still have problems after getting R9 licensed.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-9-2026
Driver Version: 32.0.16.1060
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\LTI Optics\Photopia for Rhino 8\Photopia.rhp “Photopia”
I reinstalled the beta so I could run it without an R9 license and checked it without our plug-in loaded. Doing so stopped all crashes. Enabling our plug-in caused Rhino to crash again just trying to save an empty model. We saved the crash dump file with Visual Studio and are evaluating it now. We tried plug-ins built with both the Rhino 6 API and 8 API and got the same behavior. The only major change we saw listed for R9 that we thought could be an issue is a new display pipeline. However, this crash doesn’t appear to be happening in that code. We’ll keep looking into it and thanks again for your help.
