SaveSelection takes too long
In the attached video, I have a subd object, turn on control points, then window-select points, edges, vertices, and faces by holding shift & control and dragging the mouse. With this not-too-crazy number of objects selected, I click Save Selection in the Named Selections dialog, and it takes minutes to save.
If I do the same except I don’t turn on control points first, the selection saves instantly. Something weird happens if I start with points turned on.
save selection crash.3dm (2.2 MB)
Thanks! We’ll get this patched up.
RH-97286 is fixed in Rhino BETA
