Hi maybe this is very basic or a bug…
The saved Cplane Icon persists across display modes including Raytracing and appears in every render.
How to turn it off?
N
How to turn it off?
N
not sure if there is an option in display mode.
but:
deselect all named cplanes in the panel
_namedCplane
click below in the empty area …
(currently I am on a mac - but i guess it s the same behaviour on pc/windows)
does this help ? kind regards -tom
That’s it. Thanks a lot.
@mcneelsoftware
Is this new behaviour? I never noticed it before, but I normally use the command line to change CPlanes.
It feels a bit silly that it persists after switching CPlanes. For instance, if you select a block from the block panel, it does not stay selected when you leave the panel.
Thanks, Nu
Hi Nuno -
No, this has always been like that.
Ok. It a bit misleading as well, since it stays on even if it is not the current Cplane.
I can see the usefulness of seeing it when you click on the name, but to persist after you exited the panel is a bit strange and seems unique in “panel behavior”.
Anyway, now I know. Thanks.
