Saved (Backup?) folders in AppData
I have a bunch of folders in
C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros\packages\8.0
Oldest from 23 April, 6.6GB of data.
Will Rhino clean up this automatically from time to time?
Hi Charles -
In your picture, the path that you indicate is not visible?
If you are referring to folders in the %AppData%\McNeel\Rhinoceros directory, this is what that folder looks like on my end:
I made a mistake regarding the folder name (copy&paste error).
This is correct: C:\Users\Charles\AppData\Roaming\McNeel\Rhinoceros
Ok, to avoid misunderstanding here’s a screenshot of the whole Explorer window:
That IS the folder.
I now found out such a folder is created when using the _Reset command.
