If I SaveAs, select an existing file to grab its name (say test.3dm), then change the Save as type to another format (so now it is test.dwg) I will be told test.dwg already exists (it does not), do I want to replace it.
Thanks,
Sam
Thanks,
Sam
Hi Sam - Hm - so far I do not see this behavior here.
I make a box, Save as Junk.3dm, then SaveAs, find Junk.3dm and then change the file type so that it says junk.dwg and finish - no questions other than those related the dwg file type options. Does that test what you’re reporting?
Sorry, export, not saveAs. SaveAs I do not see the warning, export I do.
Thanks,
Sam
Hi Sam – thanks, I’ll check it - I am out of the office for the most part this week but I or someone will get there.
Up… yep I see it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-41919
RH-41919 is fixed in the latest WIP
