I’d like to NOT have the resulting PDF opened after I print it. Is this possible?
Luis
Luis
Hi Luis- I think that depends upon the driver that is doing the printing. There may be a setting in the drivers dialogs as you print. I have CutePDF as my current driver and the pdf is not opened.
I was automating the SaveAs to save a PDF, so not sure how to specify the print driver in that case. Perhaps I need to manually SaveAs once with the driver I want…
Hi Luis.
In Adobe Acrobat printing preferences on the Adobe PDF Settings tab, there is a check box “View Adobe pdf results”.
Unchecking that could very well be the answer.
Barry.
When I use _Print, I can choose Adobe PDF, and I can switch this setting off, and thus the document does not open in Acrobat. But if I use _SaveAs and save as PDF, I do not have this option, and it opens up. Does Rhino come with a default PDF printer, what happens when you _SaveAs a pdf, which driver does it use? I have something called PDF995, but this driver does not let me choose to not open the document after it is created.
I was able to do what I wanted by automating the saving of various Illustrator files, but would be nice to also be able to do it with PDFs.
Hi Luis.
I just ran some tests as this issue intrigued me, and I had never saved as or exported to pdf.
I use Acrobat X and did not have it open once saved.
I did have to shut down and relaunch Rhino once I had set the Acrobat settings for it to work as you require.
I normally like to view my plot results, but turn it off when doing a batch plot from AutoCAD or Revit, so knew it definitely worked for normal plotting.
Barry.
