I configure Rhino 8 to work in a two monitor format. The viewports are on the monitor in front of me with all the panel & control information windows on my right monitor.
I should be able to see all the panel information as it updates on my right hand side. But this is not possible as some the panels don’t remember their size, length or position. Subsequently I have to fiddle with panel sizes and positions every time I open the file (a clear waste of time).
Is the position of the panels once saved via “Save Window Layout”, the same issue for everyone, or is it something unique to my computer? I have setup my right monitor to display 18 panel windows.
I tried to leave a gap between each panel, thinking that they’re overlapping might’ve caused the issue but it seems even with a gap, the problem persists.
Accelerated graphics device with 4 adapter port(s)
Secondary monitor attached to adapter port #0
Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
Just noting that when I was exporting the layout file, I was also testing the file to see if it reproduced the same errors as it did yesterday.
At first the errors were the same, then I changed the selection to “Layout F-01” and the errors were different (as expected.. it was from a layout from two days ago) Then I went back to the Layout F-02 and it came back with one error : The Help window on the right side was 1/2” short.. otherwise it was perfect..
I note that playing with it, fixed it
I was also was changing the window selection (below “Window Layouts in the first menu column)
